Purpose: Amphibious boat "Khivus-10" is intended for all round the year rescue operations, patrolling, tourism, cargo,
passenger and medical operations.
Features:
capability to move over shallow water, swamps, deep snow, broken ice and overcome gentle bank-slopes, rifts, scours and
shoals;
original design of air-cushion (RF patent No.2097231) providing high level of safety due to the increased stability and
maneuverability;
safe emergency braking on firm ground;
freeze-proof air-cushion skirt;
low-noise air propeller.
Operation area - water basins with wave height not over 1.2 m
Basic Technical Data:
| Total displacement | 2330 kg |
| Payload | 1080 kg |
| Passengers | 8-10 prs |
| Length overall | 8,25 m |
| Breadth overall (transportation) | 3,08 (2,5) m |
| Height overall | 2,55 m |
| Engine | petrol or diesel type |
| Engine power | 143 - 166 h.p. |
| Cruising speed on water | 50 km/h |
| Maximum speed on water | 70 km/h |
| Cruising speed on snow | 70 km/h |
| Maximum speed on snow | 90 km/h |
| Angle of slope overcoming | 6° |
| Clearance | 0,5 m |
| Height of obstacle overcoming | 0,4 m |
| Fuel consumption | 20-25 l/hour |
| Fuel tank capacity | 120 l |
| Range | up to 400 km |
| Propulsion system | 6-blade propeller in close-fitting duct |
| Flexible skirt | pressurized skegs, nose and aft "skirt" |
| Min. operational temperature | - 40°С |
| Max. wind speed | 15 m/s |
Description:
Hull and cabin . The hull and the cabin of the boat are made of aluminium-magnesium alloy AMg-6M. Riveting is the primary
method of connecting assemblies.. Two leak-proof bulkheads divide the hull of the boat in three compartments: front compartment,
cabin compartment and engine compartment. Such configuration ensures corrosion resistance, strength . levity and high
maintainability.
Skirt. The air-cushion skirt consists of three pressurized walls (two side walls and one transversal), flexible nose and
aft skirt. Each skirt features two-level structure and is divided into four pressurized compartments. The skirt is made of PVC
bades 5-layers cloth with polyurethane additive and fiber reinforcement. Outer sides of skeg top sections are protected with two
layers of cloth (lavsan and PVC coated capron), lower sections are pasted over with polyurethane oilcloth to prevent damages.
Engine. 4-cylinders injector type car engine ZMZ 409 or diesel engine Iveco F1C can be installed on the boat.
Air propeller. The six-blade low noise air propeller is set in close-fitting duct to increase efficiency and safety. The
blades and the duct are manufactured of fiber glass plastic. The surface of blades is reinforced by material preventing abrasive
wearing. The front of the ring duct is protected by the grid. Air propeller is driven by "Bando"toothed belt.
Propulsion units. Two twelve-blade axial fans are installed on the boat. Fan blades are made of fiber glass plastic
reinforced by material; preventing abrasive wearing. Transmission rotation from engine propeller shaft to reduction gear box
of the propeller is effected by V-belt.
Control system. The boat control system features high efficiency and simplicity. Yaw control is effected by three air
rudder driven from operating wheel (a car wheel) and due to pedal driven variation of pressure in air cushion chambers. Control
system of the boat propulsion system is standard similar to that of a car.
Interior. The boat features a spacious cabin with following dimensions: length-3.50 m; width - 1.85 m; height - 1.34 m.
Glazing of entire cabin perimeter and rear-view mirrors provide a wonderful all-round view. The adjustable driver seat is
installed fore portside and a passenger seat is installed starboard. . Four 2- seat folding benches or two 4-seat lockers are
installed after the seats. Locker seat backs set between lockers form extra berth. The cabin is finished with capron velour or
vinyl leather. It is possible to install a folding bar table.
Two high power car heaters provide comfort even at sharp frost. An autonomous heater can be installed optionally.
There are two hatches in a top ceiling.
Complete equipment. The boat is equipped with a car steering wheel, instrument panel steering system toggle switches,
storage battery of 75-hour capacity, three windscreen wipers, navigation lights, two search lights, two fog lights, cabin
illumination lights, cigarette lighter - 12V socket, four mooring cleats, two fuel tanks, siren, electrical skeg pumping system,
hand grips on the cabin top. Optionally the boat can be equipped with an anchor with an outboard end, mooring lines, hoisting
slings, life jackets, radio station, rear-view mirrors, stereo radio recorder, a heater for pre-start engine warm-up and cabin
heating with the engine off, an electrical winch, a trailer, an air conditioner, refrigerator,GPS etc.
Modifications. Optionally the boat can be modified as per customer's specification and furnished with equipment required
to efficiently perform particular missions.
